Re: Fillet at chine near
Posted by Howard on Oct 29, 2005
as lee said, you could get a little bubble there and it is no big deal. if you want to avoid that, you can go over the wire with your spatula and a bit of fillet material. this will create a sort of blister shape right over the wire eliminating any air pocket when you glass over it.
hs
In Response to: Re: Fillet at chine near by LeeG on Oct 28, 2005
