Re: fitting the coaming
Posted by mike noeske on Nov 1, 2005
Keep the edges of the coaming spacers lined up along the center line on the boat. The stairstepping will happen. The coaming ring will cover it on the outside, and you will be sanding the steps that are inside the cockpit smooth. Thats per the instructions for a Ches 16 and WR18. I imagine it would be the same for a double.
Mike N
In Response to: fitting the coaming by Brett on Nov 1, 2005
