Re: Local plywood
Posted by Moe on Nov 11, 2005
any plywood will work. however if it isn't covered entierly in epoxy and it's not watter proff rot will spread and all hell. on the finer points are diffrences in ubserbation (amount of watter wich can be ubsorbed) however plywood is almost unefected by this and even more so if it's inside epoxy.
In Response to: Re: Local plywood by Chris on Nov 10, 2005
