Re: White blobs on my ROS
Posted by LeeG on Dec 12, 2005
you either need to change the pad, use less pressure, or you're trying to remove too much epoxy with too fine a grit.,,,then of course there's the possibility the epoxy isn't fully cured and you're warming up uncured epoxy and transfering it onto the disc and not into the dust catcher. Attaching a shop vac will make the discs last longer.
In Response to: White blobs on my ROS by Ross Yahnke on Dec 12, 2005
- Re: White blobs on my ROS by Tony Robb on Dec 12, 2005
