Re: White blobs on my ROS
Posted by Moe on Dec 13, 2005
it may be do to partialy cured epoxy or beacuse you're sanding to hard or beacuse the grit is to fine A.s.o. but when you come right down to it the this will always happen. sandpaper is uneven and the sanded of epoxy will always colleckt on the sandpaper. you just have to keep changeing. i think i jused somwhere around 100 pads of sandpaper.
In Response to: White blobs on my ROS by Ross Yahnke on Dec 12, 2005
