Re: graphite and paint
Posted by Robert N Pruden on Dec 15, 2005
There is no easy way that I can figure. I have painted my boats a few times and each time, I had to paint each layer/color separately including retaping except where painted layers did not touch each other.
Advice on using graphite: mix cabosil in with the graphite coating. The cabosil helps create a tougher finish that is more resistant to scrapes and gouges that graphite alone. Use enough cabosil so that the graphite mixture does not thicken. Translation: the graphite mixture should remain paintable. I have tested this mix on the VJ Guardian Spirit, my Waters Dancing Lightning 17, and found the mix to work considerably better. I deliberated rammed the VJ over some sharp edged shale while paddling on a mountain lake last summer - the damage was minimal without any penetration into the wood. The graphite/cabosil layer was only scraped.
Robert N Pruden
In Response to: graphite and paint by ben on Dec 13, 2005
- Re: graphite and paint by Marty Sullivan on Dec 15, 2005
Re: graphite and paint by ben on Dec 16, 2005
- Re: graphite and paint by Robert N Pruden on Dec 17, 2005
