Re: Tanbark Sails...
Posted by David Bixby on Jan 7, 2006
Mark, The sail I am using has a brailing line so that I can pull one line and instantly close up the sprit and sail against the mast. Everything is stowed vertically and there is no boom in the way. I have come to really appreciate this set up. If I were building a John's Sharpy, I would definatly consider a pair of sprit rigs. The biggest obstacle I had to overcome was finding a good way to sheet the boomless sail on the narrow rear end of the Skerry. On the Sharpy this would be easy.
Mark or anyone else: If you are interested in this rig, you can read about and see pictures of the process I went through to set it up so it was reefable and could be brailed. There is also a discussion of my conversion to a boomless sail on the Skerry builder's forum (link below). Do searchs for "boomless" "reefing" and "brailing"
http://pic17.picturetrail.com/VOL855/2893683/5857341/101736301.jpg
Skerry Builders Forum at Get-Outside
In Response to: Re: Tanbark Sails... by CLC on Jan 7, 2006
