Re: Turning a pax 180 deg
Posted by Marc Geisler on Jan 27, 2006
Thanks! Should I just lean a lot, in the opposite direction of the turn, like a classic kayak turn, but more agressive? What kind of paddle stroke should I use with the lean?
Or do you mean lean into the direction of the turn? And with what kind of stroke?
I agree the speed and turning are exclusive. I wouldn't know how to install a rudder, so it looks like I need to get better at leaning turns! If I could turn the boat the way you can I'd be fine!
marc
In Response to: Re: Turning a pax 180 deg by CLC on Jan 26, 2006
