Re: SS Safety wire
Posted by BobE on Jan 31, 2006
We use the fine wire to end up with smaller less visible holes. Many will disappear by applying water to swell the wood around the hole. Many will come back into view as epoxy is applied, but we like trying.
We pull all wires before the fillets so can�t comment on sanding pad effects. As with copper, the stainless wire doesn�t rust or leave a smudge in the hole like steel wire does.
In Response to: Re: SS Safety wire by Laszlo on Jan 31, 2006
- maybe, maybe not by Mike D on Jan 31, 2006
No worries by BobE on Feb 1, 2006
- Re: No worries by Mike D on Feb 2, 2006
