Re: Fiberglass scraps
Posted by CLC on Jan 31, 2006
Nice, clean 'glass work, Peter. Thanks for sharing that.
What to 'glass extra.... I used to fiberglass rudder blades and daggerboards and it definitely makes those parts more durable. You should do the whole blade, however, not just the leading edges. The way to 'glass a rudder or daggerboard is to stand the blade on its trailing edge and drape the 'glass over the leading edge. (A temporary clamp or fixture can hold the blade in that orientation while you do the epoxy work.)
Aside from that, it wouldn't hurt to 'glass the transoms. They get dinged up over years of hard usage. Ideally the 'glass would wrap around onto the sides, but that'd be fussy to pull off and you'd have to round over the corners of the transom a lot to get the 'glass to do it.
OR---and this is my favorite---sheath the inside surfaces of the daggerboard trunk with fiberglass. (Before you assemble it, of course.) It'll be as dark and wet as the inside of a cow in there, for all eternity, and better to have it lined with 'glass, I say.
In Response to: Fiberglass scraps by Peter on Jan 31, 2006
- Re: Fiberglass scraps by John P. on Jan 31, 2006
- Re: Fiberglass scraps by CLC on Feb 1, 2006
- Re: Fiberglass scraps by Robert N Pruden on Feb 1, 2006
Re: Fiberglass scraps by Mark Camp on Feb 1, 2006
- Re: Fiberglass scraps by Greg Swarthout on Feb 1, 2006
Re: Fiberglass scraps by Peter on Feb 1, 2006
- Re: Fiberglass scraps by Obee on Feb 2, 2006
- Re: Fiberglass scraps by Robert N Pruden on Feb 3, 2006
- Re: scraps & hemostats by James Eager on Feb 3, 2006
- Re: scraps & hemostats by Robert N Pruden on Feb 4, 2006
- Re: scraps & hemostats by Peter on Feb 4, 2006
