Re: Foam Boat Constructio
Posted by Laszlo on Feb 5, 2006
Jesse,
Blue foam is not a structural foam. By the time you add enough glass and epoxy to it to make up for its weakness, you've lost any weight advantage over plywood construction.
There's also a potential problem of delamination. Since the blue foam is so weak, it can fail in shear. The glass can pull the outer 1/8 inch or so of foam away from the main core.
If you feel that you must use foam cores, you need something like divinycell, a closed cell PVC foam designed for structural use. It weighs between 3 1/2 to 8 lbs per cubic foot, depending on the grade, and costs anywhere from $80 to $800 dollars per 4x8 sheet, depending on the grade and thickness.
If I was doing this, I'd stick to wooden construction. You can make a very lightweight boat if you use monocoque construction (pre-stressed load-carrying skins) with minimal framing and thin skins reinforced with glass.
Good luck,
In Response to: Foam Boat Construction? by Jesse on Feb 4, 2006
- Re: Foam Boat Constructio by Mark Camp on Feb 5, 2006
Re: Foam Boat Constructio by Robert Strain on Feb 5, 2006
- Re: Paper boat constructi by Jim S on Feb 5, 2006
- Re: Paper boat constructi by Laszlo on Feb 6, 2006
Re: Foam Boat Constructio by Laszlo on Feb 6, 2006
- Re: Foam Boat Constructio by Mark Camp on Feb 6, 2006
