Re: Spraying Varnish
Posted by Mike Delchambre on Feb 8, 2006
I have a hvlp sprayer that I use for finishing the cabinets I build. In my estimation the finish that is sprayed is not only nicer to look at but it goes on much faster than brushing. I don't have a spray booth per say. I spray in a 2 stall garage with one door open and the other door closed down on a 30 inch fan that has a AC filter attached to it to keep the goo off the blades. Hey it works. You don't have to own a hvlp sprayer, you can rent them.
In Response to: Re: Spraying Varnish by Kyle T on Feb 7, 2006
14 days
for Discount Code Savings!
Ranging from $30 - $250
