Re: Another option
Posted by Kyle T on Feb 8, 2006
I have this system on three kayaks now and several other builders (world wide) are using it.
I started out with another hold down system but in order to get enough tension on the bungee cords to seal the hatch I couldn't get my big hands in to install and remove the bungees. Necessity is the mother of invention so I developed the Moby Latches.
They work so well that I don't even give the hatches a seconds thought when I�m hauling the boats at 75 mph down the interstate. Opening or closing the hatches is done in 15 seconds with no fuss too. They don�t leak and you can vary the tension on the bungees to hold the hatch as tight as you are comfortable.
I use 1/8 inch bungees. I tried � inch decided that was unnecessary and it made the hatch cover was too difficult to remove.
--KT--
In Response to: Re: Another option by Jamie on Feb 8, 2006
- Re: Another option by Walt on Feb 8, 2006
- Re: Another option by Kyle T on Feb 10, 2006
