Re: Deck curvature questi
Posted by LeeG on Feb 11, 2006
Make sure there isn't an excess of cured epoxy on the underside of the deck where the deck scarf is,,a thick amount of cured epoxy on the joint will prevent the curve from continueing. One thing that also helps is to put a damp cloth over the spot for about 30minutes where the deck tends to flatten, it'll make the deck bow out at that spot enough to make the minideck beam unnecessary.
In Response to: Deck curvature question by Joe Oliver on Feb 11, 2006
- Re: Deck curvature questi by Joe Oliver on Feb 20, 2006
