Re: Onlay printed graphic
Posted by mike noeske on Feb 13, 2006
It might work temporarily. But since varnish is not an adhesive it might peel up or bubble over time. And when it comes time to re-varnish the entire boat, your sanding to prep the surface would probably sand into the rice paper, and then you might end up with a "fuzzy" area.
But then again, if you dont like the looks of it, it wouldn't be hard to remove.
Mike
In Response to: Onlay printed graphics by Paul on Feb 13, 2006
- Re: Onlay printed graphic by Kurt Maurer on Feb 13, 2006
Re: Onlay printed graphic by Gober on Feb 13, 2006
- Re: Onlay printed graphic by Paul on Feb 14, 2006
- Re: Onlay printed graphic by kerry on Feb 14, 2006
- Re: Onlay printed graphic by Gober on Feb 14, 2006
- Re: Onlay printed graphic by David Warren on Feb 18, 2006
