Re: shear clamps
Posted by Mislav on Feb 17, 2006
You may not expect it but that bevel cut is the most complicated cut you'll find in construction process. And very time consuming.
As for panel beveling, yes it helps and if performed carefully can result in seams that are hardly visible from the outside. However, at the extreme angles of bow and stern I don't think it helps much. You simply cannot bevel that much. And if you plan to round the seams from the outside after filleting, the darker inside plywood layers will start to appear.
In Response to: shear clamps by tim on Feb 16, 2006
