Re: Rudder for Chesapeake
Posted by Jim Raffini on Feb 21, 2006
Thanks, Lee. It's an interesting approach. Given that the rudder stop will be installed along the centerline, I'm wondering if using that block will not create an overly sharp angle to the the rudder holder. My CLC directions recommend running the cable close to each side of the aft deck. Have you used the mahagony riser for this purpose on a Chesapeake 17?
In Response to: Re: Rudder for Chesapeake by LeeG on Feb 20, 2006
- Re: Rudder for Chesapeake by CLC on Feb 21, 2006
- that's the one by LeeG on Feb 21, 2006
