nope- you can heat
Posted by Charlie Jones on Mar 21, 2006
the screws with a soldering gun and back 'em right out. Then you can run 'em back into the same holes after varnishing, with some new caulking. OR you can just work what varnish you can underneath but that makes a messy job.
I agree revarnishing once a year is excessive unless the boat is scratched up or the varnish is getting dull.
In Response to: Re: varnishing again? by Moe on Mar 19, 2006
