wow
Posted by LeeG on Mar 31, 2006
they must have changed it to be able to sand in 12 hrs at 65degrees. I remember when it took four days.
My comment about asking for trouble had to do with removing clamped joints in 24hrs when a beginners shop environment is more likely to have variable temps compared to the thermal mass of a commercial shop space with a big concrete slab and adjacent spaces. Not that you had to have 80degree temps to build a kayak or use epoxy.
Having a constant 65 degrees would be much more desirable than a garage space that could vary from 55 to 70 degrees.
In Response to: Not Exactly by CLC on Mar 31, 2006
- Re: wow by CLC on Mar 31, 2006
