Re: Painting compartments
Posted by David H on Apr 9, 2006
I would suggest doing the majority of all finish work to compartment bottoms and sides prior to closing. The work will be much easier and you will ensure that you've closed up any holidays. Make sure you leave space for proper contact for the upper fillets on the bulkheads.
I wish I had thought ahead before closing up the hull as you have.
In Response to: Painting compartments. by Kevin Robinson on Apr 9, 2006
