Re: Discoloration of Fini
Posted by Ben Roberts on May 4, 2006
Osmosis may be your problem. Water can "wick" up exposed glass fiberif your deck is glassed. Possibly the moisture has got in from the inside. If you havn't glassed the deck then it could be getting in via crazing or hairline cracks in the finish. Don't know what the cure could be if you have glassed decks but obviously if they're just laquered then a refinish could clear it up.
In Response to: Discoloration of Finish by M Cunningham on May 4, 2006
