Re: glassing deck cutouts
Posted by Obee on May 11, 2006
I would stay away from glassing the edges as it will add thickness to the edge thereby decreasing the size of the opening. When I cut my already glassed deck and just added layers of epoxy and finally varnish I had to sand several areas where the hatch was touching the deck. Glass doesn't like sharp bends either and you may have difficulty in wrapping these edges without changing the profile of the edge. Glass the areas and trim at the appropriate time at the edges.
In Response to: Re: glassing deck cutouts by FrankP on May 11, 2006
