Re: End Pours
Posted by Chris J. on Jun 5, 2006
I used an inverted "V" of cardboard wrapped in packing tape. Cut as close to the dimensions you need then tape in place from outside. Mix a little thickened epoxy to fillet consistency and make a fillet along the inside edges and let sit for a couple of hours. This fillet will ensure no leakage. I added no more than a couple of pumps of slightly thickened epoxy at a time as it heats up pretty good if you add too much. When hardened the cardboard will pel right off leaving a nice clean pour. Just roughen up the top of the pour when your ready for deck installation.
Chris
In Response to: Re: End Pours by Laszlo on Jun 5, 2006
