Re: 17LT Bulkhead
Posted by Dave Houser on Jun 5, 2006
If you cannot keep a closed gap at the seam move the bulkhead toward the cockpit a few inches. If you are long legged check for footroom and check the station of the rear of the cockpit opening.
When filleting a gap make a dam on the back side with masking tape and fillet one side and then fillet the other side the next day. You will find the second side will have a better looking fillet than the first so do the side that does not show first.
In Response to: Re: 17LT Bulkhead by Pat on Jun 5, 2006
- Re: 17LT Bulkhead by Pat on Jun 6, 2006
