Quick Sanding Question
Posted by Chris J. on Jun 11, 2006
I've gone over the whole boat with 80 grit on the ROS (except edges, of course). I found that using the ROS takes some getting used to but after about an hour it felt real comfortable Tomorrow I'll go over again with 150 grit on the ROS. I'm aiming for a bright finish. Can I do the 220 grit phase by hand (just folded paper) or should I stick with the ROS for this also? Am I the only one not at Okumefest? Thanks for the updates Laszlo!
- Re: Quick Sanding Questio by Steve Miller on Jun 12, 2006
