Re: Sport Tandem Stabilit
Posted by LeeG on Jun 12, 2006
hard to answer with a clearcut more/less response. With a single she gets direct feedback between her and the kayak. In the ST it's possible the stability curve might be similar or even more stable but the problem is that the connection is mediated through another paddler. So if she leans and you compensate the boat doesn't tip much and it feels VERY stable. If you and she lean at the same time it will feel less stable.
In Response to: Sport Tandem Stability by Tony Calvert on Jun 12, 2006
