Re: Quick Sanding Questio
Posted by Steve Miller on Jun 12, 2006
I would have switched to hand sanding after the first pass with 80 but if you are comfy with it to this point I won't argue. Yes, do the 220 grit by hand. I like to wet sand and be sure to keep your sanding random. Remember that all you are doing is taking off the 150 grit marks - the boat should be flat and smooth by now.
In Response to: Quick Sanding Question by Chris J. on Jun 11, 2006
