Re: watertight hatches cl
Posted by James Eager on Jun 22, 2006
I have the bungees as tight as I can get em...they dont pull straight down but when you try to lift the hatch you can feel what would seem to me to be sufficient down pressure...the rims are compressing the gaskets quite well... I can understand why the aft hatch ... the stiffener caused it to flatten out relative to the surrounding deck but the front hatch should be great...I also a little concerned that a bungee might snap or a hook might give out at the wrong time...? can straps over the top provide sufficient pressure? Probably less than bungees I guess.
In Response to: Re: watertight hatches cl by CLC on Jun 22, 2006
- Re: watertight hatches cl by M Davis on Jun 22, 2006
Re: watertight hatches cl by Ron Eike on Jun 22, 2006
- Re: watertight hatches cl by craig on Jun 22, 2006
Re: watertight hatches cl by Kyle T on Jun 23, 2006
- Re: watertight hatches cl by M Davis on Jun 23, 2006
- Re: watertight hatches cl by Dave on Jun 26, 2006
- Re: watertight hatches cl by Kyle T on Jun 26, 2006
- Re: watertight hatches cl by FrankP on Jun 22, 2006
Re: watertight hatches cl by James Eager on Jun 24, 2006
- Re: watertight hatches cl by John F on Jun 26, 2006
- Re: watertight hatches cl by M Davis on Jun 26, 2006
- Re: watertight hatches cl by John F on Jun 27, 2006
- Re: watertight hatches cl by M Davis on Jun 27, 2006
- Re: watertight hatches cl by FrankP on Jun 28, 2006
