Re: watertight hatches cl
Posted by jerry on Jul 11, 2006
James, It really sounds like you have a leak in the bulkheads. I would put some water in the cockpit area, prop the bow up for a few minute and see if water gets into the aft compartment. Then prop up the stern to check the bow compartment. Should be a pretty easy fix once you find it. If you've already checked the bulkheads or don't find any leaks in them, well then...there were lots of ideas from others suggested. Happy paddling!
In Response to: watertight hatches clc? by James Eager on Jun 21, 2006
