Re: Weights: Fact or Fict
Posted by Darryl on Jul 12, 2006
Mike, press down the T.P. & roll it out about 1-3 feet to soak up the excess epoxy. Remove the piece as soon as you do this and you will see how much epoxy you can do without. Do this on areas where the epoxy looks too wet and thick. What you get is very evenly applied epoxy. For underneath the deck roll the entire area & only 1 coat of epoxy. Also shine a lamp low to see the highs & lows of your deck.
In Response to: Re: Weights: Fact or Fict by Mike Delchambre on Jul 11, 2006
- Re: Weights: Fact or Fict by Mike Delchambre on Jul 12, 2006
- Re: Weights: Fact or Fict by Darryl on Jul 13, 2006
- Re: Weights: Fact or Fict by Laszlo on Jul 13, 2006
- Re: Weights: Fact or Fict by James on Jul 20, 2006
