Re: Weights: Fact or Fict
Posted by Darryl on Jul 13, 2006
Laszlo, Use the squeegee first to spread as best as you can, then use the T.P. to remove any "excees" epoxy (weight). Don't blot it up but roll it out 1-2 feet and then remove it immediately. Do this within the first 20 mins or so after applying the epoxy & you will have no problems.
In Response to: Re: Weights: Fact or Fict by Laszlo on Jul 13, 2006
- Re: Weights: Fact or Fict by Darryl on Jul 13, 2006
- Re: Weights: Fact or Fict by James on Jul 20, 2006
