Re: How much Penetrol?
Posted by Niels G. Mortensen on Jul 17, 2006
Jim, if Penetrol is anything like Easy Flow from Epifanes (and I think it is; a fairly thin, almost watery, oil) about 5 to 10% should be fine, depending on conditions. I have recently started using Easy Flow with Epifanes high gloss varnish and find that it makes the varnish much easier to work with and the final result much more homogeneous. I doubt that adding 5-10% of Penetrol or Easy Flow will alter the characteristics of the varnish layer significantly. -- Niels
In Response to: How much Penetrol? by Jim L on Jul 17, 2006
- Re: How much Penetrol? by J. Schott on Jul 17, 2006
- Re: How much Penetrol? by Jim L on Jul 18, 2006
