Re: Drill-Fill-drill
Posted by CLC on Jul 17, 2006
I recommend that you use some silicone sealant, even in epoxy-lined holes. If the DFD process wasn't perfect you might still have a little bit of wood that will let moisture wick into the wood. Also, the silicone will keep the threads of the fasteners from corroding.
Drill, Phil! Drill!
In Response to: Drill-Fill-drill by Chris J. on Jul 17, 2006
