Re: Holes in bow for loop
Posted by craig on Jul 20, 2006
I like using 1/2" PVC pipe. It's easy to fair off to you hull, and cheap. Looks good as an accent. It would be best if you could incorporate into the endpour, but will work with a 7/8 paddle bit and some thickened epoxy to seal.
In Response to: Re: Holes in bow for loop by John S. Short on Jul 20, 2006
