Re: Holes in bow for loop
Posted by Laszlo on Jul 20, 2006
Simply drilling is faster, simpler, cheaper and gets you on the water sooner. Then, this winter, if you didn't think that the hole worked well enough and you feel like playing with your boat when the water is solid, you can always add tubes, dowels, pipes, whatever.
Simple floats sooner and higher.
In Response to: Holes in bow for loop.... by Matthew Keller on Jul 20, 2006
