Re: Holes in bow for loop
Posted by LeeG on Jul 20, 2006
get 3/8" drill,,drill hole. The only important part is to round the hole out well and slather the exposed grain well with epoxy. That way the rope won't get worn out and any wear won't expose end grain. If you turn the hull up side down and mask around the hole then slather with cabosil thickened epoxy it'll last forever.
In Response to: Holes in bow for loop.... by Matthew Keller on Jul 20, 2006
