Re: A case for steel wool
Posted by Bert van Zelst on Jul 20, 2006
You might consider using one of those new synthetic steelwool replacements. The very fine (red) pads will just scuff the surface of the old varnish layer, without removing too much, and provide just about the right amount of "bite" to hold the next layer. of course, you need to clean the sanding dust carefully afterwards (vacuum and tack cloth). I've used this varnishing the companionway boards of my sailboat and it worked well. Bert
In Response to: Re: A case for steel wool by Doug Judd on Jul 20, 2006
- Re: A case for steel wool by Mac on Jul 21, 2006
- Re: A case for steel wool by Steve Miller on Jul 22, 2006
