Re: Epoxy won't cure
Posted by Bill Brennan on Jul 30, 2006
Thanks. I will stip it off now and do the clean up.
I checked the out put og the pumps. The resin is operating fine but the hardner was only pumping out about 20% of waht it should.
Bill
In Response to: Re: Epoxy won't cure by CLC on Jul 30, 2006
- Re: Epoxy won't cure by LeeG on Jul 30, 2006
- Re: Epoxy won't cure by Tim on Jul 31, 2006
