Re: "Frostbiting" in a Sk
Posted by Jim E on Oct 3, 2006
A tip for rapid bailing: Use a bucket. Crouch in the middle of the boat, legs apart, and slam the bucket down in an arc, either between your knees or to one side, so it throws the water out. This is hard work, but a really fast way to get a flooded dinghy back into 'go' mode. Stability increases with the amount of water you get rid of, hence the need for speed. The bucket should of couse be tethered when you're not using it.
In Response to: Re: "Frostbiting" in a Sk by Bob Santore on Oct 3, 2006
- Re: "Frostbiting" in a Sk by Bob Santore on Oct 3, 2006
Re: "Frostbiting" in a Sk by Laszlo on Oct 3, 2006
- Re: "Frostbiting" in a Sk by Wilke Nelson on Oct 4, 2006
- Re: "Frostbiting" in a Sk by John Beck on Oct 5, 2006
- Re: "bailing pump by James Eager on Oct 7, 2006
