Re: Epifanes Question
Posted by Mac on Oct 16, 2006
Parke,
Coupla questions:
When you put on the first two coats, were you applying straight from the can?
And, if not how long was the can open?
Now, yes, I would try to add a thinning agent and stir, stir, stir.
I believe Epipahes is supposed to be thinned to varying degrees with each coat, so your dealer should have the correct stuff.
Don't dispair - thick and lumpy is salvageable - just look at me!
Cheers
In Response to: Epifanes Question by Parke on Oct 16, 2006
- Re: Epifanes Question by Mac on Oct 16, 2006
- Re: Epifanes Question by Parke on Oct 16, 2006
- prevents more than that by Charlie Jones on Oct 17, 2006
- Re: prevents more than th by Parke on Oct 17, 2006
- If I'm not going to use by Charlie Jones on Oct 17, 2006
