Epoxy
Posted by Kim on Oct 20, 2006
I am to the point of applying epoxy to the inside. The manual says to apply the 2nd coat within 8 hours. This seems kind of early. My garage needs heat and it is about 63 degrees. Should I adhere strictly to the manual or wait till the epoxy is no longer sticky?
Thanks Kim
- once it's tacky go for it by Charlie Jones on Oct 20, 2006
Re: once it's tacky go fo by gober on Oct 20, 2006
- Re: once it's tacky go fo by Kim on Oct 20, 2006
- Re: Epoxy by Brad Shook on Oct 21, 2006
- Re: Epoxy by Charlie on Oct 21, 2006
