Re: once it's tacky go fo
Posted by gober on Oct 20, 2006
It�s all about the temp. In the summer you may apply the second coat in an hour! Wait until the second coat does not mess up the first. I'd probably hit that first coat in the evening and let it set overnight. The next day see if it�s tacky like tape, if so go for it. If the first coat is sloppy sticky wait a bit. You don�t want to move the glass around when you lay coat #2 down.
In Response to: once it's tacky go for it by Charlie Jones on Oct 20, 2006
- Re: once it's tacky go fo by Kim on Oct 20, 2006
