Re: Epoxy
Posted by Camper on Oct 25, 2006
If a few of the epoxy runs really bother you, they come off fairly easily with a carbide scraper or a sharp block plane.
The carbide scraper will run you 10 or 15 bucks, but it never goes dull and when it does :-)you can replace the blade. It is a nice tool to have around anyway because there is no scraper like it in the world.
The block plane will need to be re-sharpened frequently, but
you may already have it; and
it is easier to use on a flat or convex surface; and
sharpening a plane iron is relaxing and enjoyable to some.
In Response to: Re: Epoxy by Kim on Oct 23, 2006
12 days
for Discount Code Savings!
Ranging from $30 - $250
