Re: Boat trailer plans
Posted by Charlie on Nov 20, 2006
The big problem with trailering kayak(s) is most trailers are sprung way too stiff for such a light load. If the spring rates aren't low enough the trailer will get airborn over every big bump and maybe even small bumps if you are going fast enough. And, of course, it will jar the living tar out of your boats. Good luck.
In Response to: Re: Boat trailer plans by Walt on Nov 20, 2006
