Re: deck glass
Posted by -Karl on Dec 11, 2006
I'm with Doug and Mac on this one. If you are going to take the time to lay on straight epoxy, why not do it over the glass? It will only take a little more time, and then you don't have to go back and do it again. It took one day to lay out the glass, wet it out and layer on a fill coat. The 4 oz. glass lays out easily, and there are no compound curves to go over on the deck. Much easier than doing the hull.
In Response to: Re: deck glass by Mac on Dec 10, 2006
