Re: Re-epoxy
Posted by Jim E on Dec 14, 2006
For an unglassed deck, it's OK to only epoxy the thin or bare patches. The tricky part is blending the edges of the new epoxy. I think I would use masking tape around the areas that need repair, then put on two or three coats, moving the masking tape outwards a bit for each coat to help with the blend. Then sand. Then put another coat over everything.
In Response to: Re: Re-epoxy by Todd on Dec 14, 2006
