Frame problem
Posted by Tony on Dec 22, 2006
I am building a Chester Yawl (1st build)I am stitching in the fore and aft frames. It has taken considerable effort to bring panels 4 & 5 on each side into contact with the frames. There is a lot of tension on the wires. After the seems have meen epoxied will the boat have stiffened enough that the frames will still fit when the wires are removed? Or am I in trouble?
- Re: Frame problem by CLC on Dec 22, 2006
