Re: Deck lines
Posted by Jim E on Dec 27, 2006
You make the holes undersize so that the shockcord is a watertight fit. Taper the shockcord by peeling back the outer cover and cutting back the elastic, then put the cover back and heat-seal the end. Poke this tapered end through the hole and pull hard.
In Response to: Re: Deck lines by Denis Royer on Dec 27, 2006
- Re: Deck lines by Doug Judd on Dec 28, 2006
- Re: Deck lines by Denis Royer on Dec 28, 2006
- Re: Deck lines by Rick Langer on Dec 30, 2006
