Re: Deck lines
Posted by LeeG on Dec 27, 2006
Mariner Kayaks did it for years. Just make sure the hole is totally sealed or drill/fill/drill. Personally the one piece of webbing held with a machine screw and nut through the deck is the best method. The hole is smaller and the bungie won't wear at the hole. Also doubled bungies with a sliding fishermans knot allow for more more effective holding of items. With the loop of bungie you can keep somethings held and another bungie free, the adjustable loop enables you to trap items well and not slide around.
www.marinerkayaks.com
In Response to: Re: Deck lines by Denis Royer on Dec 27, 2006
