20ft outriggers
Posted by Brian Cunningham on Dec 27, 2006
The large so I can fly both the other float and the kayak. Each float will support the weight of the boat. That's a lot more righting moment. I could have used a bigger kayak, but this one keeps the weight down. Multihulls get their speed from being light. The floats are also 20ft apart! So again, a lot more righting moment. 10ftx600lbs=6,000ft-lbs of righting moment. I'm running 300sqft of sail on the rig. The crossbeams are 15in high at the center to cope with the loads.
The link below is a multihull FAQ, a good read for beginners.
http://www.themultihullsource.com/frames/HomeFAQs.html
In Response to: Re: Swiftwood cad image by don on Dec 27, 2006
- Re: 20ft outriggers by don on Dec 29, 2006
Re: 20ft outriggers by Jim E on Dec 29, 2006
- 3 rudders 3 foils by Brian Cunningham on Dec 29, 2006
- Re: 3 rudders 3 foils by Jim E on Dec 29, 2006
- It's pickleforked by Brian Cunningham on Dec 29, 2006
